VAC14 Steering Play
Glenn FitzGeral
09-18-2007 17:56:58
Before I mount the new radiator on my VAC14 I'd like to get a little play out of the steering box. Are they adjustable? I have not attempted adjusting it yet.
Thanks as always,
Glenn F.
Joe (Wa)
09-19-2007 09:04:36
 Re: VAC14 Steering Play in reply to Glenn FitzGerald, 09-18-2007 17:56:58
I am not sure but think VAC14 still had the worm wheel & gear steering as opposed to the pin lever.
Go to the link, steering worm adj on page G6 G2. Page is dated 2-54, steering may have been changed later, works for my '53 VAC13.
Joe
Duane(Pa)
09-19-2007 18:38:07
 Re: VAC14 Steering Play in reply to Joe (Wa), 09-19-2007 09:04:36
That link is the coolest thing I've seen lately. There is an eccentric under that front cap that moves the worm shaft closer to the worm wheel to bring them into tighter mesh. There is a special tool listed because you have to apply rotational force to the eccentric. You may be able to rig something easier than finding the tool.
Duane(Pa)
09-19-2007 18:41:03
 Re: VAC14 Steering Play in reply to Duane(Pa), 09-19-2007 18:38:07
Oh, and if you need that front bearing, it's the same as a john deere governor bearing. Ask me how I know!
Uggie
09-19-2007 04:31:39
Good morning, there are two different locations that can cause the steering to have extra play. 1. The u joints in the steeering shaft. The carrier bearings that support the shaft. 2. Inside the casting with the steering gear there are three pins that work with a worm gear. Worked on a 351 case once and it only had one pin that steered the tractor and it was about 1/16th thick the other were worn and completly gone. Glad I check before I went flying down the road. If I had hit a pot hole it probably would have sheared of and lost control. They use to make replacement pins but they are now unavaible at the dealership. I have a guy that made my replacement pieces. I have a original pins and he may be interested in making more if there becomes a need for them. Biggest issue is they aren't cheap. So how much play in the steering is to much play? That is up to you and to the safety of driving the tractor down the road. Hope this helps.
