Diesel timing
dieselpuller
09-18-2007 14:47:37
I have a Case 1270 that I am modifying and was wondering how to advance the timing 4 degrees. What does it take, and what direction do I turn the pump? Any advice will help.
mEl
09-18-2007 15:47:57
 Re: Diesel timing in reply to dieselpuller, 09-18-2007 14:47:37
remove the 1 1/4 plug on the timing cover just ahead of the injection pump mounting base Clean the oil off the drive gear so the scribe lines are visible. set the engine on compression on number one cylinder then set the timing markyou desire on the front damper to line up with the pointer. then loosen the pump and rotate it till the scribe line on the drive gear lines up with the scribeline on the injection pump. tighten pump
mEl
09-18-2007 15:47:54
