Case 1030
crb
09-18-2007 10:00:56
I have an opportunity to buy a case 1030 but I'm concerned about the cracked head/sleeve notes I've read on this forum. Is there a way to quickly test for this when viewing the tractor, ie, look for bubbles in the radiator, take a compression check, etc?
Thanks, crb
Dairy farmer in WI
09-19-2007 19:12:53
 Re: Case 1030 in reply to crb, 09-18-2007 10:00:56
like roger said, make sure there are no bubbles in the radiator. also be careful since a mechanic told me those blocks are prone to cracking sice it's just a Case 930 block bored out bigger which made them somewhat weaker. not real thrilled with mine right now. it had a TOTAL of 8 cracks on the deck of the block. not trying to turn you off of it just want you to be carefull. i bought a pile. it was all fine when i bought it but now i'm looking at over a $3000 overhaul plus a new block. just look to see if the radiator has bubbles. if it does just walk away
Good luck
DF in WI
Roger (Mi)
09-19-2007 06:08:41
 Check for bubbles in reply to crb, 09-18-2007 10:00:56
Make sure the radiator is totally filled to the top of the neck. Start the engine. If bubbles appear, there is a problem with sleeves or a head. My 1030 has never had head or head gasket problems. The problem was always sleeves until I replaced them with Sealed Power sleeves. I have 8 tractors, and the 1030 is my favorite.
