case AW9
don in SD
09-18-2007 06:46:43
I have a case AW9 windrower and need to see a picture of how they attach to the drawbar of the tractor, seems something on this one is missing, any help will be appreciated
Don
BarryfromIA
09-18-2007 17:29:00
 Re: case AW9 in reply to don in SD, 09-18-2007 06:46:43
There was a short bar that bolted to the small hole in the draw bar. It was 12in or so long and had a square bar welded to it near the bolt hole to hold it at approximately a 45 degree angle on the left side of the draw bar. There was a chain attached to end went that back to the right side of the frame that the square hitch tube was attached to. I believe this was to make the windrower pull to the end of the cut when turning a corner. Dad pulled ours with a VAC with the wheels dished in and slid in as far as the would go. Or maybe we are talking about two different machines.
don in SD
09-19-2007 05:27:41
 Re: case AW9 in reply to BarryfromIA, 09-18-2007 17:29:00
We are talking about the same machine I think, mine has the bar and chain, do you recall how the tongue was attached to the drawbar of the tractor, it has a square tube bar with a round pipe like piece welded to the drawbar tube it is the same height as the tube, attached to the right side of the tube at the front, does this go direct to the drawbar or do i need to look farther, thanks Don
BarryfromIA
09-19-2007 06:11:01
 Re: case AW9 in reply to don in SD, 09-19-2007 05:27:41
The square tube goes to the drawbar just like any other hook up.
don in SD
09-19-2007 10:02:00
 Re: case AW9 in reply to BarryfromIA, 09-19-2007 06:11:01
does a bolt go down thru the side of the tube,
where there is a pipe like welded on to the side of the tube, and does the tube go on top or bottom of the drawbar,
Don
BarryfromIA
09-19-2007 17:26:40
 Re: case AW9 in reply to don in SD, 09-19-2007 10:02:00
Yes. It has been 42 years since I have seen one in operation, but I believe that is correct.
BarryfromIA
09-19-2007 17:30:29
 Re: case AW9 in reply to BarryfromIA, 09-19-2007 17:26:40
I did not answer the whole question. The tongue goes on top.
don in SD
09-19-2007 17:48:51
 Re: case AW9 in reply to BarryfromIA, 09-19-2007 17:30:29
Thank you so much ,,it is all starti;ng to make sense now, i found this machine which has been shedded for years and still looks new, i want it for parades, wood looks new, nice little windrower.
thanks again Don
BarryfromIA
09-19-2007 18:24:02
 Re: case AW9 in reply to don in SD, 09-19-2007 17:48:51
What are you going to pull it with.
don in SD
09-20-2007 03:40:48
 Re: case AW9 in reply to BarryfromIA, 09-19-2007 18:24:02
the only case i have is a DC which is too big i mite put it behind an alis B or JD H, or an earthmaster,
or cockshutt, ford naa leader D, old WC Alis mite work, i haven,t made up my mind have about 50 choices. Don
