Battery
Rod in MN
09-17-2007 19:45:04
I have a 1941 LA Case tractor And I have a battery question is it a 6 volt or a 12 volt the old battery was gone so i do not know what was used Thank you Rod in MN
caseman-d
09-18-2007 18:45:40
 Re: Battery in reply to Rod in MN, 09-17-2007 19:45:04
One would be surprised what some good 2/0 battery cable will do for a 6 volt system. I use 2/0 on most everything, on some 12 voilt systems I use a 1 gauge. Thats because what we stock, would preferr 1/0.
caseman-d
Dave Olson
09-18-2007 16:29:30
third party image
I tried to stay with a 6 volt for a '38 L. Even with new wiring and the starter rebuilt the 6 volt battery had a very hard time turning over the engine.
I ended up putting a 12 volt battery on it. It has a 6 volt generator and I've thought since the engine is running off of a mag I will be able to connect up the lights and generator.
Dave Olson - East-Central Illinois
Gene Dotson
09-17-2007 20:03:42
Original equipment was 6 volt negative ground. Used a group 4 battery... Gene
