case 530 brake job
Mikeleone
09-17-2007 06:25:43
No brakes on the 530 I just picked up, A few questions if someone could help me out:
1. The removable backhoe is welded in place, Am I screwed? Will those brake covers come off with the hoe support arms in place?
2. Will removing the covers allow the gear lube to drain ? If so how much should I expect?
Anything else that I might to run into?
Mikeleone
09-18-2007 11:22:57
 Re: case 530 brake job in reply to Mikeleone, 09-17-2007 06:25:43
Thanks for the advice guys, this helps a lot. The machine is in the woods at my camp so bringing the right tools out with me is important. I'll bring the compressor and die grinder with me.
I'll let you know how it turns out.
again Thanks
Phil (NJ,Az,Sask)
09-17-2007 23:24:32
Mike, The Hoe is most likely welded to the rear bracket, and that bracket is bolted to the back side of the axle Trumpet with the same 4 bolts that connect the FEL bracket (You should not need to remove the hoe or FEL). The interference is actually with the FEL bracket at only one location, the pivot bolt head. The pivot bolt only needs to be unscrewed, about 1.0", to clear the Transmission Housing. The pivot bolt stays with the Brake Assembly and comes off as a unit. All other bolts are removed completely.
You may need to grind the FEL Bracket at the point where the pivot bolt head makes contact, its not much, and may already have been done. My 530CK had one side done (torch) but the other side was not. The assembly must come off on an angle until it clears the bracket, wiggle and pull forward (its the brake band that must clear the drum).
Hope This Helps
Phil (NJ,Az,Sask)
09-18-2007 07:30:02
 Re: case 530 brake job in reply to Phil (NJ,Az,Sask), 09-17-2007 23:24:32
BTW, The axle trumpet Flange (FEL,Hoe) mounting BOLTS should have been installed with the NUTS on/to the REAR (hoe) side.
bradley martin
09-17-2007 09:35:07
Removing the covers will not drain the oil unless the pinion seals are completely shot. However, if you do find oil in the brake housing, you would be advised to replace the seals before rebuilding brakes.
BarryfromIA
09-17-2007 17:09:05
 Re: case 530 brake job in reply to bradley martin, 09-17-2007 09:35:07
You will have problem's clearing the bolts that mount the hoe to the axle, unless it is mounted different than the older ones. You might be standing on your head or feel like by the time your get them off. The brake cover is held on with studs that are in a hole drilled through the housing. They have a strong tendency to unscrew from the housing before the nut comes off.
BarryfromIA
09-17-2007 18:57:41
 Re: case 530 brake job in reply to BarryfromIA, 09-17-2007 17:09:05
You could look it up on the CNH website.
