sc front steel wheels
justincase
09-16-2007 21:31:56
Did the SC ever come out with optional pressed steel front wheels... Or where they all cast?
L.Lamp
09-18-2007 19:25:26
 Re: sc front steel wheels in reply to justincase, 09-16-2007 21:31:56
I have a '44 SC that I am trying to pull with. I wanted to get down to 3500# with me on it but no such luck. I pull in 4000# and tried 4500# and 4600# but I don't have enough horses for the last two classes. Allis Chalmers WD wheels will fit an SC. I have a pair on my '54. You will want to go to 5.50 tires as the 6.00x16's touch at the bottom. I got rid of the starter, generator, long draw bar, standard battery, foot rests and fenders. I tried to use a Case Mag but I couldn't keep it firing at the end of a pull. I have installed an angle drive distributer and use a 200 amp lawn mower battery for ignition. It weighs exactly 4000# with me on board. This set up retains the radiator weight and the heavy front wheels.
justincase
09-19-2007 19:07:13
 Re: sc front steel wheels in reply to L.Lamp, 09-18-2007 19:25:26
Thanks L.Lamp. I haven't stripped her yet but I can't get in to 4000. Don't have fenders. 12 volt alternator. Case mag freshly charged It sees pretty hot. I crank it and sometimes will start just turning to get a better position of the crank. I mean I barely turn it over and it fires kinda neet. Would like to find out... mag vs distributor which is better for pulling. I like not needing a battery. I have fenders but in storage since new. Is your '44 stock?
justincase
09-18-2007 18:59:44
Thanks to all for the info. I am thinking about pulling my grandfathers '49 SC. I've learned a lot since dragging it out of the weeds and having the vales ground. New manifold. Found the weight under the radiator on one in the junk yard and sure enough mine had one too. That had to be pulled. Just sets in there! Odd. I think I'll find a pair of steel wheels loose some weight!
Ry
09-17-2007 19:29:51
What's the matter - are you tired of trying to mount tires on those heavy cast suckers? Ha! Ever notice how heavy SC and DC tractors are compared to the John Deeres of the day? Most SCs even have a large weight under the radiator. Case was not cheap with the iron.
C. Amick
09-17-2007 09:12:15
The early SC's had pressed steel wheels. I think the AC WD wheels are pretty much the same adn are available after market.
DKase
09-17-2007 19:31:22
 Re: sc front steel wheels in reply to C. Amick, 09-17-2007 09:12:15
AC"s and DC"s were 16". SC"s were 15".
C. Amick
09-18-2007 09:13:43
 Re: sc front steel wheels in reply to DKase, 09-17-2007 19:31:22
Do you know what the bolt circle diameter is on an SC? If it is 5 inches, they should bolt up? If he is just looking for a lighter weight wheel for pulling purposes a 16" should be ok?
DKase
09-18-2007 11:19:37
 Re: sc front steel wheels in reply to C. Amick, 09-18-2007 09:13:43
Bolt pattern is the same, but you would have a tough time finding a 16" small enough to fit under an SC. I have 14" Olds wheels on mine, and 195's just fit under.
C. Amick
09-18-2007 12:19:35
 Re: sc front steel wheels in reply to DKase, 09-18-2007 11:19:37
Didn't the SC come with 16" wheels the last couple years that it was made?
BarryfromIA
09-17-2007 17:13:01
I have a set of cast weights for steel fronts.
BarryfromIA
09-17-2007 05:20:00
Yes
