Re: 2390 hydrolic troubles
Damp;Dservice
09-16-2007 20:39:49
On the 90 and 94 series tracors there is a suction screen for the hydraulics that is located in the rear section, it is a cone shaped screen that will become plugged with brake lining and power shift debris, as you operate the tractor cold the material is at the bottom of the case, but as you keep using it and it warms up the material collects around the screen and shutting down the flow, eventually you only get enough oil so that the priority valve only has enough oil to operate the powershift , steering and brakes. It is a difficult problem to diagnose as there are other problems that can act the same, such as internal high pressure leaks. a comprehensive flow test is about the only way to know for sure, we get a few tractors here every year with new pumps on them with the same problem, the worst news is you have to split the tractor at the 2nd split to access the screen, you can take a hardware magnet that vets put in cattle, remove the drain plug and stick it into the case through the drain hole, we attach a small chain to it and attach it to the drain plug so it doesent travel around, run it for awhile and then remove it, if there is alot of material on it, it is likely the suction screen being filled. Hope my rambling on helps.
4435
09-17-2007 06:51:55
 Every little tidbit helps in reply to Damp;Dservice, 09-16-2007 20:39:49
Thanks
