ROOSAMASTER PUMP
OL'CK
09-16-2007 08:28:15
HAS ANYONE EVER TRIED FILLING AN OLD ROOSAMASTER DBG INJECTION PUMP WITH EITHER WD-40 OR PB BLASTER PENETRATING CATALYST OR SOMETHING ELSE TO FREE UP EITHER A STUCK FEUL SHUTOFF (METERING VALVE) OR STUCK PUMP OR CHECK VALVES? THANKS, OL'CK
Damp;Dservice
09-16-2007 20:24:27
 Re: ROOSAMASTER PUMP in reply to OL'CK, 09-16-2007 08:28:15
You can sure give it a try, however the parts in these pumps have what is called a "class fit" meaning that even the oils in your skin can seize these parts if you handle them without taking the proper precautions, if they seize and you are successful in freeing the parts they will likely be scored badly enough that it wont run for long and then send metal filings into the injectors.
