900 front end part broken
toolz
09-15-2007 22:21:05
Just bought a 900, Runs great, straight tractor, but noticed a broken front end part today. I don"t know what you call it, but it"s the casting that holds the pivot pin for the front axle, and bolts to the bottom of the big front end casting with 4 bolts. Both sides are cracked around the rear bolts. Anybody got one to sell me?
Also, the pivot hole through the axle is pretty worn. Is there a fix for this? Thanks for your help. Kevin
toolz
09-16-2007 19:45:40
 Re: 900 front end part broken in reply to toolz, 09-15-2007 22:21:05
Thanks for the help, guys. I'm amazed with the results this board gets. A lot of good people here. Kevin
george md
09-16-2007 18:37:07
Kevin,
The piece you are describing is the pedestal and part # is A20347 and is updated to an A 21103 . The bushing for the axle is A7519 and most likely the pin is worn also , pin # is A7518. If you don't find one , hunt me down and I'll weld it for you . It will not be done with arc weld it will be O/A welded .
george
bradley martin
09-16-2007 02:39:28
There would have been a bronze bushing in the axle hole that can be replaced....likely still available from Case.
