fuse block
drderdon
09-15-2007 16:24:36
Would someone please tell me where the fuse box is on a Case 580K. I have been running down
wires, figured it would lead me to the fuse box. And I have half of the panels off, no use. I can"t find it anywhere.
Don
BasketCASE
09-16-2007 07:40:20
 Re: fuse block in reply to drderdon, 09-15-2007 16:24:36
There may or may not be a fuse block in that tractor. If there is, it is connected to what they call the engine harness. There is, I think, a fuse block that takes the spade type fuses mounted to a bracket, but it should be easily accessible. If you cannot find a fuse block, there were some models that did not have a fuse block in the harness. If a diagram helps more, see your local dealer, or go to www.casece.com and they have parts diagrams online.
LenND
09-15-2007 18:07:54
I"m going to ask a dumb question. Is there a fuse box in that tractor. Older cases had one fuse on the dash and that was it . MY2Cs.
drderdon
09-15-2007 21:35:36
 Re: fuse block in reply to LenND, 09-15-2007 18:07:54
Ok thank you very much. Didn"t even figure that it could only have one fuse. It"s a 1991 580K.
Now I know the answer I was looking for.
Don
