LA Case power
Tom W
09-12-2007 14:45:37
What are guys doing to the LA to get the power. I Know the Long 6in stroke helps but on tractordata it said it had a comp. ration of 4.09:1 that sound kind of low. Are you putting high comp. pistons and head on them, Maybey LP heads. Also is the LA a sleeved engine? Iv heard that guys will punch the block out to WAY over 403. Is this so? Is that what these guys do to get the big power. How are they doing it?
Gene Dotson
09-12-2007 16:33:51
 Re: LA Case power in reply to Tom W, 09-12-2007 14:45:37
Tom;
The low compression was for burning kerosene. Case furnished high? compression pistons of 5.7 to one for gasoline only. Kerosene engines were rated at 51 horsepower and gasoline engines at 64 horsepower.
My LA has a 4 7/8" bore and a 5854A, I believe, propane head and developes about 90 horsepower. It has 448 cubic inches and about 8.0 to one compression.
The pullers go as high as 1100 cubic inches with a 9 inch stroke and not sure how big the bore is. Naturally, this takes a lot of expensive machining, both on the cylinder bores and the bottom of the cylinder block and crankshaft. Not for the averaage mechanic or pocketbook... Gene
