magneto timing
ny farmer
09-12-2007 09:37:00
Good morning, My coupling to the mag came loose and spun around, Does anyone out there know how to retime the mag?? i would like to learn in the simplest way possible. thank you in advance.
Walt Davies
09-13-2007 07:56:39
 Re: magneto timing in reply to ny farmer, 09-12-2007 09:37:00
My LA has a Bosche mag on it so it won't time on the mark on the flywheel.
I put it on top dead center #1 remove the front side cover to make sure it it top dead center then mark front pulley and block with a punch or chisel. use a tape to measure 1.5 in. before TDC on pulley and place another mark on pulley the use a timing light to set it at this mark with Mag at full advance. this will be 30 degrees BTDC. It should run good at this setting.
Walt
ny farmer
09-13-2007 04:03:04
good morning, thank you for the quick responses,Dave what is thing that looks like a generator,located ahead of your mag ,in your pictures. thank you ,Larry
Dave Olson
09-13-2007 19:14:21
 Re: magneto timing in reply to ny farmer, 09-13-2007 04:03:04
third party image
Yes, that is a generator. This is a '38 L, with electric start, generator and lights.
Dave Olson - East-Central Illinois
ny farmer
09-12-2007 09:38:04
Sorry, the tractor is a 1951 LA
Dave Olson
09-12-2007 16:54:09
 Re: magneto timing in reply to ny farmer, 09-12-2007 09:38:04
third party image
Hello ny farmer,
My L was out of time and we found that the coupling needed to be adjusted and tighten in place. After much searching I found a fellow close by that had the special wrench and the know how. The old L runs great now!
Dave Olson
Mathias NY
09-12-2007 09:56:57
Generally, place the number 1 cylinder at top dead center of the compression stroke. Then place the magneto so that it is about to fire cylinder #1. Loosely attach the magneto, rotate it until it snaps, then tighten the bolts.
My 'D' has a small inspection hole just in front of the belt pulley. When piston #1 is top dead center a 'D' is visible on the flywheel through the inspection hole. I'm not sure if an LA has the same setup.
