David Brown 885_Maintanance_ Oils?
Gabriel
09-11-2007 15:26:40
I just inherited this old Tractor,it runs good and is in pretty good shape. My question is;
1. What goes in the power steering resivoir and does it operate anything but the steering?
2. What does the small dipstick in front of the right shifter go to, Trans? It looked like it had clean motor oil in it until I put a little Hy/tran oil in the steering resivoir, now it's milky looking! I also greased all the grease fittings. How did that oil get milky??? I have pictures if anyone needs to see it.
pa dave
09-11-2007 18:01:49
 Re: David Brown 885_Maintanance_ Oils? in reply to Gabriel, 09-11-2007 15:26:40
we use atf [automatic trans fluid] in the power steering resevoir. the dipstick is for your trans and rear and hydraulics. milky oil is usually a sign of water in oil. should be changed, can damage internal parts. our 990 DB can't set outside in rain or will end up with water in trans fluid, it will turn milky after you run it a while, let it set long enough it will seprate, making oil look clean again, hope this helps, DB,s where great tractors
Gabriel
09-12-2007 13:49:41
 Re: David Brown 885_Maintanance_ Oils? in reply to pa dave, 09-11-2007 18:01:49
Thanks for the reply. I did hose it off while cleaning old dried grease off it, maybe some water got into it somehow. On the transmision, How much and what kind of oil goes in it, and "where in the world would it go in at"? (My guess would be Hy/Trans fluid like I used in the steering resevoir, it does have an over flow tube about 2 feet long coming from the resevoir can and going into the transmision near the dipstick.) These are probably stupid questions but how would you know unless you had a manual or someone tells you.
