Big 400
tuggle
09-11-2007 05:59:41
I have been looking for a gas tank for my '56 400 on eBay for some time now and found one from an 800. Is this the same tank and will in fit????
INCase
09-11-2007 13:25:46
 Re: Big 400 in reply to tuggle, 09-11-2007 05:59:41
As Jim said they are not the same. It probably could be done if you change some parts. There is a chance the 400 hood has the same shape as the 700/800/early 730/830 you"ll have to set them together and see. You may also need the 800 mounting brakets. The dash however would definately not be compatable. I"m sure someone out there has a 400 tank.
Jim from Calif
09-11-2007 07:58:16
No: they are not the same. Different sheet or the 400 vs the 800.
