Case 500 Belt Pulley Question
Bobl1958
09-10-2007 19:40:03
Wondering if a belt pulley for a DC will fit on my 500? Also, can you buy the rubber dowels that go between the pulley and the shaft? Thanks - Bob
Bobl1958
09-12-2007 10:29:50
 Re: Case 500 Belt Pulley Question in reply to Bobl1958, 09-10-2007 19:40:03
Thanks to all for your replies. I have a belt pulley for a DC and tried to get it on the 500, but it looks like the ID of the pulley is slightly too small to go on the shaft. Thanks again - Bob
Paul f
09-11-2007 13:57:47
You can get neoprene rubber rope (1/2" dia I believe) from McMaster.com and cut it to the lenghts you need..
HW
09-11-2007 04:49:32
I never saw the need for the rubber dowels. I used some hardwood dowels in place of them.
caseman-d
09-10-2007 20:08:24
The 500 belt pulley should be 13 dia and 8 1/4 face. I was thinking the D's were smaller?? Pin nimber is O7643AB and rubber is O7644AB I do show the LA's had a couple of different part numbers.
caseman-d
