case 310 backhoe
mikepush50
09-09-2007 07:44:10
I have a case 310 backhoe. The hydraulics are real slugish and jumpy. Is there a bleed valve for the system? I couldn't find one in the manuel. Also if the rams leak a little will it put air back into the system?
Dennis/Ohio
09-12-2007 05:31:18
 Re: case 310 backhoe in reply to mikepush50, 09-09-2007 07:44:10
Had a collapsed suction hose. Looked OK on the outside but inner lining was collapsed.
Best, Dennis..... .....
TimBinWV
09-09-2007 09:56:18
System should bleed the air out the vent.If the rams leak,they simply lose fluid. More than likely,you have a dirty filter,or a pump going bad.Good luck with it.
mEl
09-11-2007 06:19:18
 Re: case 310 backhoe in reply to TimBinWV, 09-09-2007 09:56:18
while the items previously mentioned could be a problem I would check the condition of the oil after running it for a bit.get some in a glass jar and look for bubbles throughout the oil, if present, you may have an air leak on the suction side from the reservoir to the pump. The pump seal could allow air to enter but should show wetness from seepage of oil out, don,t overlook your oil as the problem In many older units people are going cheap and useing engine oils for hydraulic oil. Hytran ultra or TCH are excellent choices for quality hydraulic oil as they get rid of air readily and are readily available at Case dealers, I have worked my career(45)yrs as a mechanic for a Case utility dealer and have grown up with these units. Chech these issues and let me know what you find, i'm curious. mEl
mikepush50
09-11-2007 19:54:16
 Re: case 310 backhoe in reply to mEl, 09-11-2007 06:19:18
mEl
The people I bought the 310 from blew a hose and replaced it but didn't put oil in it. I bought the hydraulic oil form the case dealer and put about 4 and a half gallons in. When I run it, it looks like foam comming out of the vent on top of the tank. When I have some daylight left after work this weekend I will check out the pump.
Thanks
Mike
mikepush50
09-09-2007 14:03:08
Thanks for the reply. That is what I kinda thought but wasn't sure. I couldn't see a filter on it. This has been parked for quit awhile, so I will run it longer to see if the air bleeds out.
Do you or any one know a good place to buy parts? Maybe hydraulic seal kits etc. Thanks again Mike
