430 PTO
Hubbsy
09-07-2007 15:53:41
Have just bought a 430 and the PTO shaft seems to want to keep turning even when I try to disengage it with the lever. I have not attached an implement yet, so don't know if it will still do it under load. I have noticed that once or twice when the tractor is turned off, the shaft seems to have disengaged (you can turn it easily). Tractor is otherwise A-1. Could this be just due to lack of use, or is it something I need to check right away? Thanks!
Lincoln
09-07-2007 18:27:34
 Re: 430 PTO in reply to Hubbsy, 09-07-2007 15:53:41
The PTO brake is probably worn out or out of adjustment. Push the lever all the way down and it will probably stop. You can adjust it by tighening down the spring on the lever. The PTO on my 600 is the same way. It always stops when I have an implement on it.
