530 rear wheels lock up when in 4th gear
ponytail
09-06-2007 19:01:26
I have a 530 std clutch dual range shuttle shift. When I put it in 4th gear the rear wheels lock up. Sometimes just the left other times both. Then sometimes it locks up after just a few feet other times 50 or 100 ft.
All other gears work fine and it doesn�t seam to mater if it is in low or direct drive. took the top off the transmission and it looked ok in there as far as I could tell. (no broken off teeth I could see or pick up with a magnet)
Anybody have an idea what it could be. Any help would sure be appreciated.
630Crazy
09-07-2007 17:14:46
 Re: 530 rear wheels lock up when in 4th gear in reply to ponytail, 09-06-2007 19:01:26
probably the faster you go the worse or more apparent the back lash becomes.
Jason Weir
09-07-2007 13:03:39
I had the same problem on my 530CK, I assumed it had something to do with the brakes because if I reversed direction it would release immediatly.
Sometimes it would lock up every 2 feet sometimes it would go for ever.
Here is the WARNING... About a month ago the thing broke the ring and pinion gears.
I found a message here on ytmag that indicated if the ring and pinion gears were not setup correctly (backlash and gear mesh) it would cause the lock up problem and eventually break the gears. I'm now looking for a parts machine so I can fix mine..
-Jason
ponytail
09-07-2007 14:33:35
 Re: 530 rear wheels lock up when in 4th gear in reply to Jason Weir, 09-07-2007 13:03:39
mine will release right away without having to put it in reverse. going in reverse in 4th gear it seams to lock up even quicker
I thought it might be in the brakes or rear gearing except that it only does it in 4th gear.
