case 1030 heads
loneranger27
09-05-2007 19:12:21
Hi, I just found out from my head doctor that 2 of my 3 heads are beyond repair and I need to replace them. Does anyone have any good used ones that are guaranteed not to leak or know of someone who sells rebuilt heads that is reasonable. Worthington ag parts has them listed at $371 each without valves. I think it is a little steap myself after i include the cost of valves. Then I should probably get tyhe new valves ground to match the seats.
Thanks
Bison
09-07-2007 13:50:16
 Re: case 1030 heads in reply to loneranger27, 09-05-2007 19:12:21
Would heads from a 970 fit? i got 3 good ones in my shop
INCase
09-07-2007 11:04:54
When I was shopping around for 800 gas heads they ranged from 325 to 450 w/o valves. Can"t fine the # for the $325 place. Somewhere in central Ill. 830 diesel heads may work for you as well.
djm75
09-06-2007 03:59:07
if it is a diesel put new valves and seats and don"t grind them you wont get the valve protrusion you need.
