case 430 triple
Bob K Mi
09-05-2007 17:52:10
HELLO ALL
I just came across a 430 triple no manuel.
I need to know what the lever on the left
side does.
Have tried dif.pos.but only one way works
It has a bucket.
Cant find proper manuel yet
Thanks Bob
JGarner
09-06-2007 05:47:07
 Re: case 430 triple in reply to Bob K Mi, 09-05-2007 17:52:10
Bob, if the tractor is a '64 it's like Barry said. This long handle is a "secondary clutch" to stop the tractor's motion while the PTO is still running. On the Triple Range if you push in on the clutch the tractor and PTO will stop, Case-O-Matic is like the older Case tractors and has an independent (live) PTO with its own clutch.
With the 430, 530 and 630 pulling the handle back is like pushing in on the clutch for the tractor but doesn't effect the PTO. Good when you are baling, cutting hay with a cycle bar mower or bush hogging. If the implement begins to bog down the tractor can be stopped and the implement allowed to catch up.
BarryfromIA
09-05-2007 18:03:37
If it is an early 430 and the lever is down low on the side of the transmission case it is the hand clutch to stop forward motion while keeping the pto running.
Bob K mi
09-05-2007 18:24:22
 Re: case 430 triple in reply to BarryfromIA, 09-05-2007 18:03:37
I think he said it was a 1964.Thanks Barry.
I will check into it this weekend
Bob
