Stuck valve on the CASE SC
Greenfrog
09-04-2007 20:39:52
The valve will stay down. Can pry it up, but persists in staying down. I can pry it down and it stays down. Spring not broken. Rocker arm is ok, and push rod goes up and down, but rocker arm doesnt move sice the valve is not pushing it back up. What could possibly be holding it down? How do I free it up. I did grab gently with visegrips and rotate it, but this did not help. Appears to be an exhaust valve from what I can tell--is the fourth valve back. Kind of neat to watch it run with the valve cover off. I was in the process of replacing the cover gasket. I could tell that it was stuck by the way that it sounds, but at times runs fine when warmed up. Thanks in advance for your input.
Walt Davies
09-05-2007 08:17:33
 Re: Stuck valve on the CASE SC in reply to Greenfrog, 09-04-2007 20:39:52
Rust in valve guide a little light oil or penetrating oil on the valve guide will free it up you will have to move it up and down a few time until you free it up.
Walt
