511/611b and 630 axle
630crazy
09-04-2007 16:35:26
One of our brethren needs an axle for a 630(GP). Anyone know the difference between the 511/611 axle and the 630 axle. Two different part#'s but they look the same and used the same bearings, seals and bull gear.
I guess the critical thing would be the length of the shaft from the bull gear to the outer oil seal.
LongCase
09-04-2007 16:51:05
 Re: 511/611b and 630 axle in reply to 630crazy, 09-04-2007 16:35:26
I have a pair of axels from a 630 GP . Keyway type not flange.Let me know if i can help.
Larry Neohio
09-05-2007 13:41:47
 Re: 511/611b and 630 axle in reply to LongCase, 09-04-2007 16:51:05
Can you give me some measurements on the over all length and the distance accross the outside end of the shaft? The one that ended up broken is 40 1/2" long and measures about 2 1/2" accross the outside end. Also has 17 teeth on the splined end.
Thanks,
Larry
