580ck loader
sam un ont
09-04-2007 08:56:06
my 580 has developed a leak between the torque tube and the tranny . i split the tractor and found a chunk of metal in the torque tube and a small sliver between the tranny seal and the tranny. i see nothing really wrong with the seal but noticed that the main trans. shaft is hollow and that the manual calls for a plug at the end.what is the purpose of it i need help sam
sam un ont
09-04-2007 12:33:08
 Re: 580ck loader in reply to sam un ont, 09-04-2007 08:56:06
i found out what the piece of metal was from it is the end of the starter housing that had worked it,s way back. am i correect in assuming that the shaft is hollow to facilitate a p.t.o. shaft if so equipped and the end plug when not equipped with a pto is to stop the transfer of fluuids. when i pulled the cover off the diff there was no end plug sam
