disk ID
karl f
09-04-2007 08:10:30
need assistance identifying a case disk we have to get parts. it's a 14 ft wide tandem with 14 inch blades and 2 wheels per lift arm. the hitch is a-frame construction with height adjustment provisions. also the front and rear gangs are adjusted fore and aft by turning large screws. the body is in flambeau red with only Case on it a few times, scripted in the yellow/tan color. cannot find a model number or plate on it anywhere. there are no fold down gangs on it. it is lifted with one cylinder.
thanks
karl f
bradley martin
09-05-2007 01:31:57
 Re: disk ID in reply to karl f, 09-04-2007 08:10:30
Karl; It sounds like a "B", first available in l966-'67. available in widths from 9-21 ft.
karl f
09-04-2007 23:41:04
after about an hour and a half on the case ih site, using the word harrow in the parts search, looks like it is likely a B series. will have to check the blade spacing, diameter etc. the blades might be very worn!
karl f
karl f
09-04-2007 21:09:09
also the wheel hubs use standard 6 bolt implement rims--case yellow/tan. about a 5 inch wide rim. gang bearings are bearings and not wood or babbit or any early engineered thing.
caseman-d
09-04-2007 20:02:59
Biggest one I found in my book was a 13ft. It was a S-138 use with the LA.
casemna-d
caseman-d
09-04-2007 19:53:10
Can you post a picture of it??? Makes it a whole lot easier.
caseman-d
karl f
09-04-2007 21:05:59
 Re: disk ID in reply to caseman-d, 09-04-2007 19:53:10
no on the picture, haven't a way to get a photo to the computer...or a regular camera for that matter! will search a little see if i can find an image online
