VAC hydro question
Gregg Morrison
09-04-2007 05:49:28
My recently aquired 1951 VAC has already baptized my tools. While mowing this weekend one of the hydraulic lines from the front mounted pump (no belt pulley) to the Eagle Hitch control unit started leaking. I removed the hoses and am having new ones made today, but I haven't gotten any manuals for this tractor yet.
So I have 2 questions:
1 - Where is a good source for parts/repair manuals? I had factory info for my Deere and would like to find something similar for this tractor.
2 - What oil/fluid should I use for the hydraulic system, where do i fill it, and what is the procedure for filling?
Thanks in advance
Gregg
BarryfromIA
09-05-2007 18:10:59
 Re: VAC hydro question in reply to Gregg Morrison, 09-04-2007 05:49:28
Use any good oil for Case hydraulic. Follow the suction line for the pump, you will find a fill plug on the torgue tube in the middle housing between the clutch housing and the transmission.
Robert E. Smith
09-05-2007 17:31:05
Try this fellow, Vern Schultz 12510 Wilson Road.
Coopersville Michigan 49404 Ph.616-837-8850
They are 20 bucks each and he has Dealer Service manuals,Dealer parts manuals and Operators/Service manuals for about any type or brand of tractor, engine, lawnmower, diesel engine or two wheel tractor ever made!
If you cant find it anywhere else I'll bet he's got it! And his prices are cheap!
Picked up a manual for my VAC and my Cub Lowboy from him last weekend in Trenton Ohio at a Tractor show must have spent 2 hours just looking thru his diplays at all the different manuals he had, It was amazing
Bob Smith
C. Amick
09-04-2007 09:10:38
You can buy manuals for it on this web site under Marketplace, Tractor Manuals. You can also find some information on-line by clicking on the link I listed below.
