VA shifter grinding
jason, NW Ontar
09-04-2007 05:05:15
I"ve had the VA hooked up to our log splitter for the last 2 weeks, and when I had to move it forward a foot, I was unable to shift into any gear. Only grinding. Never happened before. Had to shut it down just to shift into gear.
Any ideas?
Gregg Morrison
09-04-2007 08:01:20
 Re: VA shifter grinding in reply to jason, NW Ontario, 09-04-2007 05:05:15
Sounds like the clutch disc has stuck to either the pressure plate or the flywheel. This is especially a problem if the weather has been damp. Sometimes you can free the disc by starting the tractor in gear with the clutch depressed - but be careful, if the disc doesn't break loose the tractor will move as if the clutch is engaged.
jason, NW Ontario
09-04-2007 19:25:25
 Re: VA shifter grinding in reply to Gregg Morrison, 09-04-2007 08:01:20
Thanks for the advice - I'll give that a try next week once I'm done splitting wood.
jay
