cylinder 3$3 not firing
heenk
09-03-2007 16:31:31
On my SC the magneto is good but #3 and #4 don't fire but have spark. On the airintake are two small vacuum bolts.remove the one between 1$2 and the engine stolls. remove the one between 3$4 and 1$2 reff up. but 3 and 4 don't respond.
How can I get 3$4 to work I've tried a diff magneto with the same result.
Ry
09-04-2007 19:02:01
 Re: cylinder 3$3 not firing in reply to heenk, 09-03-2007 16:31:31
Good point Klyde - Hey, also make shure the plugs wires are on in the right order.
Klyde
09-03-2007 20:51:12
Not to be a smart a-- but how about a couple new plugs in 3&4 first..
Ry
09-03-2007 17:17:29
Do 3 and 4 have good compression? If not the head gasket could be blown between the two. Also check the valve adjustment and make shure the back 4 valves are opening and closing - I have seen a 4 cylinder that would fire only on the front cylinders because of a camshaft that was broken in half! At any rate a cylinder needs spark - fuel - air - compression to fire "don't forget the spent fuel needs to get out so check your exhaust". So you just need to figure out which one is missing.
