600 crank wiggle pin
josh kuhn
09-02-2007 15:46:30
got a diffrent crank for my 600 same casting #s but does not have the 2nd oil hole on #6 jounal to oil the clutch. Is it really nessary i dont relly understand what purpose it serves other than may be let some oil get to the piolet bearing. open for suggestions thanks.
JHH
09-06-2007 19:45:19
 Re: 600 crank wiggle pin in reply to josh kuhn, 09-02-2007 15:46:30
Your "600" needs that oil passage and wiggle pin to let oil into the clutch housing. The clutch is what is known as a wet clutch, it runs in oil. The wiggle pin lets a little oil from the crankshaft journal into the clutch, then there is a trough near the top that catches the oil that the flywheel slings off and drains it back into the crankcase. Smoothest clutch made, it would probably burn up without the oil.
Roger S
09-05-2007 21:56:02
I parted out a 600 irrigation motor, it had a rear crank seal and dry clutch. Your crank probably came out of an irrigation motor.
