Not likely a governor problem
Roger (Mi)
09-02-2007 13:52:08
If the engine spits, sputters, and stalls, better check the amount of fuel getting to the carb. Remove the gas line at the carb, and let if flow into a quart jar. It should fill the jar in about one minute. If the governor is not working properly, the engine will come to a gradual stop without spitting or sputtering.
pinto paso
09-03-2007 06:16:06
 Re: Not likely a governor problem in reply to Roger (Mi), 09-02-2007 13:52:08
Thank you - this may very well be what he is looking for..
Stefanie
pinto paso
09-02-2007 16:11:15
Thanks, will have him check that although he has done quite a bit with the fuel system - he seemed to think it was the governor under load... and was hoping to find out how to adjust it (not in the manual)..
I will call the shop tomorrow
Stefanie
Gene Dotson
09-02-2007 17:53:38
 Re: Not likely a governor problem in reply to pinto paso, 09-02-2007 16:11:15
Sounds like you need to adjust the rod from the governor to the carburetor. with the engine stopped, open the throttle lever to full wide open position. Check the clearance at the carburetor arm and wide open stop pin, The clearance here should be 1/16 inch. Shorten or lengthen this rod to get this setting. Easiest to hold the carburetor lever against the pin and adjust the rod till the pin just slips through the hole... Gene
