Major carburator flooding
JRT
09-01-2007 21:37:41
Today I was hauling rocks with my 310 Case and it failed to start. Motor acted like it would not turn over kind of like the starter was locked. I was turned down hill so rolled it off to start it. It began to start and at least a pint of gasoline came out of the exhaust pipe, soaked the tractor and me with gasoline like a heavey rain. The right spark would have set the tractor and me both on fire. The tractor never had flooded before. I continued to work but turned the gas off every time I stopped. If I didn't, the thing would flood like a water hose and the motor would not turn over. I finally took the carb apart and found nothing wrong. I adjusted the float, checked the float needle and nothing wrong. Put it back, and same thing. Major flooding. I had an extra float so I dicided to put it in and see what happened. That fixed it. I could not see anything wrong with the float that was in it. No holes, and I tried several adjustments. I still dont know what was causing it. Any ideas. Also the business of the motor not turning over when it was flooded. Never heard of that before. Is that possible or is that a seperate problem?.
Klyde
09-02-2007 06:00:27
 Re: Major carburator flooding in reply to JRT, 09-01-2007 21:37:41
If the carb drain hole is plugged, and enough gas is in the carb and air cleaner pipe. A leaking float valve will fill the pipe, carb, manifold and whatever cylinder intake valve is open. When the intake valve closes you have a very good hydrolock. It dosen't take but a speck to make the valve leak and maybe you missed it the first time through.
