case dc late need help
havvey
09-01-2007 05:57:52
found a dc with foot clutch (presume live pto) 3 pth Tires shot motor stuck (could be toast also) narrow front. Is this worth saving? what is its value in said condition. Also what am i in for to overhaul the big case motor?
John Saeli
09-01-2007 17:04:46
 Re: case dc late need help in reply to havvey, 09-01-2007 05:57:52
A Foot Clutch DC is very desireable. One of the last ones. Yes, it has live PTO & Hyd's. An adjustable wide front is even better. A Sleeve & Piston kit w/ gaskets is $836. Tires & Tubes could be around $700. Hopefully the rims are OK. Go for it!! You won't regret it.
BarryfromIA
09-01-2007 18:27:26
 Re: case dc late need help in reply to John Saeli, 09-01-2007 17:04:46
Where are you located? I might make a deal on a set of 12-38 tires from 1953. They have been in side untill the last 6 years.
ry
09-01-2007 17:01:31
If you don't save it give it to me and I will!?
J Heitkemper
09-02-2007 15:24:02
 Re: case dc late need help in reply to ry, 09-01-2007 17:01:31
. Very good ,tough, economical ,versatile ,dependable tractor. Need I say more ...other than if You decide you are not up to doing the project,And < Should you decide to pass and if it is anywhere close to Indiana ,, I am willing to take on the project ,, Just drop Me A line . Thanx jim
caseman-d
09-01-2007 07:39:59
If you would like the eadle hitch it's worth saving. You could get over 1000.00 in overhaul if you need piston and sleeves. then you don't know whats wrong with the rest of the tractor. If rims are ok you could get another 300.00 in good used set of rear tires.. I never consider my time into fixing my tractors. I work cheap .
Another option would be find another D series enginea and stick into the tractor. Some The SP9-12 I believe had the D series engine in it. Eagle hitch if complete makes it worth more. You might pull the pan covers and look up into thesleeves and see how much rust is below the pistons to determine how bad it is inside.
caseman-d
