Case DB 1210
Robert Barnett
08-30-2007 16:20:35
I am replacing the crankshaft but can not figure ot how to get the engine out. I followed the shop manual. Removed Xmsn cover, PTO assembly etc I can not locate a snap ring on clutch shaft the book says is there?? it ahs seprate PTO and clutch actuating bearings and one tube inside another the inside tube is bolted to the Xmsn. All is loose except these two tube things. How do I get the clutch assembly clear of the Xmsn to lift the motor out?
seantn
08-31-2007 00:51:18
 Re: Case DB 1210 in reply to Robert Barnett, 08-30-2007 16:20:35
The transmission shaft is hollow. The snap ring is behind the coupler. Remove the snap ring, slide the coupler back to the transmission. The PTO shaft comes out the back. The engine and clutch will lift away and you do not have to even split the tractor.
seantn
Hilltopper46
09-04-2007 10:42:11
 Re: Case DB 1210 in reply to seantn, 08-31-2007 00:51:18
A 1210 likely has the 12-speed transmission in which event the snap ring and coupler is not there. If so, the tractor needs to be split.
