fuel priming case 504bdt engine
George Steele
08-30-2007 16:09:45
case 1080b excavator engine 504bdt. replaced rod bearing and rod, removed head for nbr 3 and 4. after putting back on had major problems priming fuel system. Only cyl 6 had fuel to it rest were dry. Put on new filters and primed but still only get fuel to 5 and 6. black smoke and no power. Then couldn't shut down engine. It ran on about 1500 rpm's and only way could shut off was to disconnect fuel line from tank and let it run dry. Oil pressue and temp normal. Need help please.
Thad
08-30-2007 17:56:24
 Re: fuel priming case 504bdt engine in reply to George Steele, 08-30-2007 16:09:45
Has this unit sat for along time? Sounds like the rack is stuck in the pump to me. The plungers can stick in the bore's of the pump after they sit for along time. That will cause one to run wide open and be unable to shut it down. You cant get rpms cause its probubly only hitting on a few cylinders. Hope this helps. Thad
george steele
08-30-2007 19:19:25
 Re: fuel priming case 504bdt engine in reply to Thad, 08-30-2007 17:56:24
Yes, it was sitting 8 months with the center head off. My first time with this type of pump, can I unstick the racks? The lines were taped off while it was open but noticed several dirt dobbers had made a home under the tarp. Any advice appreciated. Thanks
case trader
08-30-2007 17:25:08
i just done one mine started no priming at all. that said you think you could have a return line restriction? do you have any press. at inj. line i assume it has a primer pump like tractor should be able to pump up tight you would have to think it was something that transpired during repair,i would look at return line.
George Steele
08-30-2007 19:36:46
 Re: fuel priming case 504bdt engine in reply to case trader, 08-30-2007 17:25:08
Yes, is has a hand pump and pumped up tight but still only got fuel to nbr 6 which is the first line in from the filters. After a second try got fuel to nbr 5 and it would stay running but smoked like crazy and still no fuel to the rest. Could be return line problem will check in the a.m. When I primed it with pump the return line pressure side shot a long stream but I didn't check the return end back to tank. Thanks
