Case Model C
bcdave
08-30-2007 08:18:44
I am looking at a Case C on steel. Can anyone tell me what it would weigh so I can lift it out of the garden? I am also curious about value. It is old and rusty, engine is stuck and is missing the mag. Any info would be much appreciated.
Thanks DAve
bcdave
08-31-2007 07:31:44
 Re: Case Model C in reply to bcdave, 08-30-2007 08:18:44
I live in British Columbia Canada. I have a 1937 Model C with 12x24 cutoffs. I just removed the calcium and repaired some pits in the rims. It is one of my show tractors. The C on steel is about 2 hours away. We're still trying to come up with a price. I'd like to be able to hook it up to my plow and go into a plowing match (after I get it running) If anyone has the color code for the gray paint I would appreciate getting it.
Thanks Dave
James Herrman
08-30-2007 22:12:47
Have an original 29 C on steel and anyone is welcome to look at it. Am in Central Ill, south of Peoria.
Nedd
08-30-2007 14:32:37
Where are you located? Or where is the tractor located? Mine is on cutoffs and would like a close look at one on steel.
Brian in Ohio
08-30-2007 19:19:44
 Re: Case Model C in reply to Nedd, 08-30-2007 14:32:37
I have a "C" on steel, and I live in Southern Ohio, near Cincinnati. You're more than welcome to come look at mine.
Dave Olson
08-30-2007 14:29:12
third party image
Hello Dave,
My '30 C weights 3300 pounds as you see it in the picture. No fluid in the tires.
Sounds like the little tractor may need a boat load of work. With that in mind I would not pay very much for it, but thats just me! :-)
Dave Olson - East-Central Illinois
mshultz
08-30-2007 10:11:16
I have a 29 C w/cut-offs and 14.9 x 24 tires (not loaded), and it weighs around 3500 pounds empty.
