2670 roof seal,
kirk in ks,
08-30-2007 08:08:24
I need help on putting a new seal in the roof of my 2670, I dont want it to leak thru the blower vent's, when it rain's,
do I silicone it, or do I put a new seal in there as i dont want it leaking again, and the one that's on it now is sloppy looking, and all rough around the edge;s like some one didnt do it right,
Jim B
08-30-2007 20:56:58
 Re: 2670 roof seal, in reply to kirk in ks,, 08-30-2007 08:08:24
Kirk, You asked this same question about a month ago.
At that time I suggested that you use Low Density Foam Tape, available at any good automotive paint supply store. If you use Silicone Sealer the roof will be nearly impossible to remove without damage... it will be basically glued-in.
Check your earlier post, I offered step-by-step procedure to make the repair.
kirk in Ks,
08-30-2007 21:37:30
 Re: 2670 roof seal, in reply to Jim B, 08-30-2007 20:56:58
hi jim,i was gonna get the original part for the roof, youi mean this wont work,
or,, will it leak with the original part,,, i guess it will , as Ive asked people about this, and it seem's like the rubber does swell,
or Ill redo it with the kit you talked about,
kirk,
