Case 830
spiceman16
08-30-2007 05:28:13
Does anybody know how much a Case 830 weighs? I need to go get one half way across the country.
Patrick (Mich.)
08-30-2007 21:53:43
 Re: Case 830 in reply to spiceman16, 08-30-2007 05:28:13
I own a 1963 830 diesel, dual-range. It has a wide front, two sets of rear weights, but non-loaded rear tires. When I rolled it over the scales at a tractor show, it read 8600 lbs.
Hoss in Maine
08-30-2007 15:38:42
yup,a big 12 volt battery later Hoss
casefan
08-30-2007 14:29:08
My 830 narrow front gas with no weights and no fluid weighs 6650.
Gene Dotson
08-30-2007 06:34:16
Typical working weight will be approximately 8000 lbs. May be higher with diesel engine and Case-O-matic.
The 830 8 speed was tested at Nebraska with a bare weight of 7125 lbs.
.. Gene
JGarner
08-30-2007 05:41:16
Tractor Data says it weighs 6,300 lbs, I assume this is a weight without fluid in the tires which could add (I'm guessing) another 350 or so pounds.
