SC Case Transmission Hyd
Ande
08-30-2007 04:53:56
The owners manuel really does not talk about the hyd very much,is the filler hole for that,right behind the trans? And to check is the little plug down a ways from that? Same 90 weight oil? Also where is the inspection plug for the trans?
Ande
C. Amick
08-30-2007 09:19:18
 Re: SC Case Transmission Hyd in reply to Ande, 08-30-2007 04:53:56
No, don't put 90 wt. in your hydraulics. Use hydraulic oil, motor oil, or automatic transmission fluid. I think the inpection plug for the transmission is on the same side, perhaps further toward the front of the tractor than where you are looking?
Ande
08-30-2007 14:35:56
 Re: SC Case Transmission Hyd in reply to C. Amick, 08-30-2007 09:19:18
Thanks "C" I will look there,my owners manuel does not tell me much,I wonder if it is for a older "SC"
Ande
