Putting 3 point on VAC
Duane WI
08-29-2007 13:20:01
I just got a VAC that has the older hydraulic lift system with rocker arm under the gas tank. The rocker arm attaches with a rod to a second set of rocker arms under the clutch and brake pedals. I found a 3 point kit that came off of a Farmall Super C that worked off of the hydraulic rock shaft. I measured it up and it looks like it will fit the VAC and I could run it off of the rocker arms under the clutch and break pedals. Does anybody have any idea how well this will work? How much would it lift?
C. Amick
08-30-2007 09:12:32
 Re: Putting 3 point on VAC in reply to Duane WI, 08-29-2007 13:20:01
If you go to the link listed below, you will find a VAC tractor manual showing an aftermarket 3-point hitch assembly. It may help you in trying to figure out how to make yours work. Dad made one for his VAC to lift a rear blade. I don't know how much more weight than that it will lift.
