VAC Eagle Hitch Draft Arms
Paul f
08-29-2007 06:23:12
The design of the draft arms and claw indicate that the claw could rotate within the draft arm (In my case 50+years of corrosion mean no movement). Rotation was limited by a bolt that passes through the claw and the arm. My eagle hitch DC has no such rotational capability.
Why did the VAC have the rotation capability and is it worth trying to free up the claw ends???
Gregg Morrison
09-07-2007 09:26:42
 Re: VAC Eagle Hitch Draft Arms in reply to Paul f, 08-29-2007 06:23:12
If you consider the presentation that most turning (land) plows need when in use you'll see why the claws rotate. A properly set-up turning plow has a signifigant tilt to it, and if the pick-up points don't have enough offset to provide this tilt it must be provided by altering the length of the lift arms (most need at least 2 or 3 turns even with offset pick-ups). If the lift arms are set to different lengths there must be some give to the pin orientation at the implement end - typical 3 points provide this with the rotation of the captured ball, while the Eagle Hitch does the same by allowing the claws to rotate.
C. Amick
08-30-2007 09:15:20
I don't know the reason for it and I don't see why you would need them to rotate.
Paul f
08-31-2007 06:05:13
 Re: VAC Eagle Hitch Draft Arms in reply to C. Amick, 08-30-2007 09:15:20
Thanks...I really didn't want to have to try to free them up.
mj
08-31-2007 21:04:43
 Re: VAC Eagle Hitch Draft Arms in reply to Paul f, 08-31-2007 06:05:13
If you dial in a lot of tilt to a rear blade or whatever the rotation keeps the "claws" and pins from binding.
Paul f
09-02-2007 07:07:20
 Re: VAC Eagle Hitch Draft Arms in reply to mj, 08-31-2007 21:04:43
Thanks I had not thought of that...but the VAC doesn't have to work the back blade that's the DCs job
