Need to replace rockshaft piston seal
Roger (Mi)
08-29-2007 06:00:05
There is supposed to be a mechanical stop on the 3 point lift lever. It prevents the rockshaft piston (lift) from reaching the end of its travel. Check that adjustment. The reason hydraulic oil is going into the rearend is a defective rockshaft piston seal. You'll need to remove the rockshaft housing, remove the piston, and replace its seals. The rearend is supposed to have 90W gear lube filled to the low mark on on the plug/measuring rod.
