Your opinion, Mylar or Vinyl decals???
JGarner
08-27-2007 12:44:45
Which holds up best?
Which is easiest to put on for professional look?
Supplier for decals for 630 in mylar? vinyl?
Don L.
08-27-2007 15:54:42
 Re: Your opinion, Mylar or Vinyl decals??? in reply to JGarner, 08-27-2007 12:44:45
Mylor holds up better. Mylor goes on easier.
Vinyl looks more professional.
Case 630"s are only available in mylor.
Don L.
ACEd
08-27-2007 15:10:02
Don't know about originals being mylar - maybe depends on year - but as I recall mylar came out in late 60's - first time I encountered it was in recording tape as replacement for acetate or vinyl base - its principal benefit was it was stronger and did not stretch - kind of the opposite of vinyl which generally stretches pretty good. We used vinyl on race car decals as late as the 80's - probably longer - but that was when I got out. Advantage to vinyl was that it did stretch and stick to contours that were not perfectly flat - disadvantage was if you didn't watch what you were doing you could stretch / distort big pieces before you got them down. I guess I'd probably go with vinyl based on experience with it.
RustyFarmall
08-27-2007 14:04:48
Original decals are mylar. If your tractor had been shedded all of its life, the original decals would still be there. Does that tell you how long they last? I think the mylar decals are far easier to apply.
K-Mo
08-27-2007 14:00:23
I know Maple-Hunter has 630 decals. They worked with me to build a set several years ago. I think they deal in both mylar and vinyl. Give them a call and see what they say.
Maple-Hunter Decales
Riley IN
765-9322027
812-894-9759 K-Mo
triplerange
08-27-2007 13:18:17
Don't know...I was hoping your 630 would be willing to be a guinea pig to my 630. LOL
JGarner
08-27-2007 13:52:21
 Re: Your opinion, Mylar or Vinyl decals??? in reply to triplerange, 08-27-2007 13:18:17
Hopefully some of the guys that monitor this site have a little more experience with this than you and I. I think 630crazy will be intersted in what comes out of this too!
All I know is the ones that are on it now look like vinyl. I don't know how long they have been on and if the tractor sat out a lot or not (looks like it did in a former life). They are in very bad shape and they don't look like they were very easy to put on or the person applying them didn't know all the tricks.
Thinking about stripping off the sheet metal this winter and letting by local body shop guy work on it as filler. Need to go vist him and see what kind of price he can work out for me. He's a much better painter that I and I figure its the sheet metal that needs the most care. Cast iron is more forgiving paint wise. Doing my homework since I will need to procure a decal set in a few months.
Jim B
08-27-2007 20:09:59
 Re: Your opinion, Mylar or Vinyl decals??? in reply to JGarner, 08-27-2007 13:52:21
In my humble... paint is better than any decal!
If you want it to look better than original hire an artistic sign painter who can duplicate the graphics exactly, then clear-coat to protect for the rest of our lives.
JGarner
08-28-2007 14:25:15
 Re: Your opinion, Mylar or Vinyl decals??? in reply to Jim B, 08-27-2007 20:09:59
Not a bad thought, but guess I would need to buy a set for a go by for him. Don't have any Case guys with 30 series tractors, other than me, in our club here. If I get a set for a go by might as well put them on and as well I will get all of the other safety and caution decals in addition to just the hood decals. Plan to keep the old girl inside except for when I am playing with her so the vinyl ones should last for a good long time. Thanks for the idea though, I might do a bit of investigating. Case parts site shows the decals for other 30 series as available stock still so that may be where the safety and caution ones come from unless Maples-Hunter sells open stock.
