580ck
sam un ont
08-27-2007 08:18:18
i have an older 580ck case with a convertor and power shuttle. recently i have started to lose fluid from the torque tube with no idea of where it was going until i checked the dipstick just to the rear of the tranny and it was incredibly overfull. it appears that i have a leak internally and know that i will have to split the tractor.i do have the manual but it is not really specific as to what to look for . does the diff share the same oil as the tranny or is it separate aany and all help is appreciated sam
sam un ont
08-27-2007 11:55:59
 Re: 580ck in reply to sam un ont, 08-27-2007 08:18:18
i pulled the cover off the tranny and i see the tube in question and it is securely sealed so it looks as though no easy fix sam
Charlie from ME
08-29-2007 13:26:28
 Re: 580ck in reply to sam un ont, 08-27-2007 11:55:59
Sam,
Sorry to hear you did not have any luck with that "simple" fix. Maybe splitting the tractor won't be so bad....ugh!
regards
Charlie in ME
08-27-2007 08:54:33
Sam,
I have the same issue with my 580 CK (1969). The attached link has some information regarding this issue that you should evaluate before you consider splitting the tractor. It may save you considerable work. I have not gotten this far with the issue yet as the tractor seems to work ok with Hytran in the finals. Cut and paste this into your brouser. It should bring up the string of dialog around your tractor's problem. See the reply by mEl.
Let me know how you make out.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=case&th=82963
