Paging C. Amick
Casekernel
08-27-2007 00:38:45
Tried to e-mail you, but doubt if it went through. From archives and previous posts, it sounds like you have an SC-49 tractor with the same type of pump as mine. How is yours plumbed? I know you added a second cylinder on the right for lifting heavier equipment. But how would it be plumbed with just the original work cylinder on the left?
2nd question: do you have "down pressure" capability with your pump and work cylinder(s)?
C. Amick
08-27-2007 18:19:06
 Re: Paging C. Amick in reply to Casekernel, 08-27-2007 00:38:45
I had brackets welded onto the right side of the draw bar assembly that matched what was on the left and added an identical cylinder on the right side. I put tees in the hydraulic lines to split the flow to each cylinder. Yes, I have down pressure. You must attach the connection for the center link to as many bolts as possible or you may break something. I ran a heavy flat piece of metal under the seat and rebolted the seat. It will pick up a 5.5 ft. disc mower with no problems, except keeping the front wheels on the ground.:)
