case 600 dsl
josh kuhn
08-26-2007 14:07:35
what exactly do you have to machine to get a 377cid to to use a later 401cid 930 sleeve and piston
rcgrey
08-26-2007 18:46:17
 Re: case 600 dsl in reply to josh kuhn, 08-26-2007 14:07:35
Block needs to be machined top and bottom for 930 sleeves to fit but then aftermarket 4 1/4" kits are avalable that will also fit making 426 cu in.
caseman-d
08-27-2007 20:44:15
 Re: case 600 dsl in reply to rcgrey, 08-26-2007 18:46:17
rcgrey said: (quoted from post at 18:46:17 08/26/07) Block needs to be machined top and bottom for 930 sleeves to fit but then aftermarket 4 1/4" kits are avalable that will also fit making 426 cu in.
When I was thinking of rebuilding my 500's I was chatting with a Case mechanic down in Missouri ??(some where in that area) I was told about having to rebore the block and that the 930 heads would not fit the 377 un less you drilled new bolt holes. He did tell me that if I took the heads off a 257 that they had bigger valves for increase power. It's been several years since I've talked with this guy and I hope I have the information correct.
caseman-d
LenND
08-27-2007 14:33:08
A few years back there was a kit that made a 900B into a 930 and you didn't touch the block or head of the 900. Everything fit right in. I don't remember who sold it, could have been TSC.
Jim McVay
08-26-2007 18:39:29
My dad got a set of sleeves and pitons from Don Livingston for his 900 to make it a 401.
LenND
08-26-2007 14:14:05
I may be wrong (won't be the last time) but I think they fit right in. The sleeve wall is made thinner to fit bigger piston and rings.
