2090 fruel tank
chickey
08-25-2007 17:15:46
Ok, so I punched a hole about the size of dime in my fuel tank. Is there an epoxy or any way to patch the thing?
135 Fan
08-25-2007 19:11:34
 Re: 2090 fruel tank in reply to chickey, 08-25-2007 17:15:46
Clean the tank really good and make a metal patch to cover the hole. A rad shop might be able to solder it for you or you could try soldering it, brazing it or welding it yourself. Epoxy could work also. Let it dry overnight before using it. If it's repaired by any method using heat steam it out with the hottest water available and leave the filler open so pressure won't build up inside. Dave
T.K. in PA
08-26-2007 04:39:30
 Re: 2090 fruel tank in reply to 135 Fan, 08-25-2007 19:11:34
2090's have poly tanks!
chess
08-25-2007 19:03:13
There is a kit from Case--A44363--- That should fix you up. It is a piece of fiber an some other stuff to smear on.
