bummer - cracked crank - DC
grapefarmer
08-24-2007 13:45:27
third party image
I was happily putting in new sleeves and domed pistons and I found a hair line crack in the crank. Not sure what I want to do, not really looking forward to pulling the engine all a part, getting a new crank and having all the bearings re-babbited. Might just bolt it back up and see how long it lasts...
-Dave
Chico, TX
dboll
08-28-2007 08:27:05
 Re: bummer - cracked crank - DC in reply to grapefarmer, 08-24-2007 13:45:27
I would be concerned about cleaning up that deck and studs!
Nebraska Kirk
08-25-2007 16:44:10
Boy! I dunno, if that crank decides to let loose, you are liable to end up with bent/broken rods, damaged pistons, a larger hole in the block, and a lot more work and expense than if you were to change it now.
TimBinWV
08-24-2007 18:40:25
Grapefarmer,my Daddy had a sayin' that just may apply here..."If it can't take it,It can't stay!"
Hope all works out well!!!
grapefarmer
08-25-2007 09:38:47
 Re: bummer - cracked crank - DC in reply to TimBinWV, 08-24-2007 18:40:25
You Dad my be right, but I am going a head and putting it back together. I am going to only use the tractor lightly. I will keep an eye out for a cheep parts tractor and fix it on a later date.
-Dave
grapefarmer
08-24-2007 13:48:04
third party image
Other pictures of the DC can be found at Link
