old 300 gov....
farm-al
08-22-2007 19:13:10
I have an old round nose 300 under a backhoe loader, it has a 148 engine,the problem is there is no stop on the throttle rod with the spring that hooks to the gov lever,no place for any bracket on the engine block or stop bolt in the throttle rod bracket, has any one got an old 300 that can tell me whats missing? thanks farm-al
farm-al
08-23-2007 06:06:30
 Re: old 300 gov.... in reply to farm-al, 08-22-2007 19:13:10
Many thanks guys for the info,looks like someone has put the wrong gov spring on it,I will double check the rod to the carb. too. thanks again,farm-al
Joe (Wa)
08-22-2007 21:53:07
The link is a VA series service manual. The 300 series 148 cid engine throttle linkage is identical to figure S-30 & 31 except the carb throttle plate lever actuates from the bottom as opposed to the top as shown.
Adjustment procedure is the same except 300 series rpm differs. Disregard VAI speed blocking.
When the site loads, click on pages G2-S26 & G2-S27 to enlarge for reading.
Joe
Mike in Ont
08-22-2007 20:49:26
Ihave a 311 amd had a problem with over reving when Ifirst got it a little adjustment on the rod running from carb to gov was all that was needed.Someone had switched it to 12 volt and modified the rod.Engine should rev at 1925 rpm with no load and 1750 under load.There is no stops on mine.Hope this helps. Mike
