case heads
midlam
08-22-2007 10:37:52
are the 730,830,930 and 931 diesels heads interchangeable? the casting numbers are different. I think some may have a cover for compression release linkage.
bradley martin
08-22-2007 18:00:59
 Re: case heads in reply to midlam, 08-22-2007 10:37:52
As Incase stated ,730 & 930 heads are identical and 830/l030s identical (I'm talking diesel, but the gasoline versions would interchange in the smane manner). Early year models had the decompression mechanism opening but I have seen engines where that opening was sealed over with a piece of sheetmetal or even plywood secure w/cap screws.
INCase
08-22-2007 10:46:34
730 and 930"s should be interchangable. 830"s and 1030"s should be interchangable. I think (may be wrong) that Case had some other head numbers they used for replacment heads later on. Look in the CaseIH web page parts section for each tractor model and you may find other head #"s. My 800 gas had 2 different heads, the original and the other was a later, 1970"s vintage replacement with a different #.
