Hydraulic symptoms...What do you think?
owlafaye
08-22-2007 08:18:52
My Case Model 310 has a front loader and a 3 point hitch.
Raising and lowering started slowing down. Now nothing works. When cold, I can engage the 3 pt. hitch or loader and they will work very slowly a couple of times and then nothing.
There is a two way valve under the seat for engaging the 3 pt. hitch or by-pass to the loader. The loader has a dual control valve arrangement. Fluid from the pump goes to the 2 way valve where it engages the 3 pt hitch in one position (discharging oil directly into case where the 3 point hitch arrangement is) or it sends hydraulic oil to the 2 valve front loader arrangement.
One mechanic speculated that a seal had been lost in the 3 pt. assembly located in the case and I would have to dismantle the entire back of the tractor.
What do you think?
owlafaye
JGarner
08-22-2007 11:53:21
 Re: Hydraulic symptoms...What do you think? in reply to owlafaye, 08-22-2007 08:18:52
I think your mechanic exagertated the dismatle job. I believe the 310 3pt is set up similar my 630. Taking the whole rear end apart is a bit over the top. I had mine apart and he hardest thing to do was pick up the rockshaft cover after I had the seat, tool box, lift arms off and cover bolts out. It probably took me about 45 minutes to dismantle it.
One word of caution, make sure you keep hold of the rock shaft whe you lift the cover off to set it aside. There is nothing that holds it in place and it will slide out of the housing and fall on the floor or in the dirt if you aren't careful. Luckily I caught mine before it hit the concrete.
I haven't done it but I hear the hardest part of this job is getting the 3pt lifting piston back in the bore after you put the new seal on.
Joe (Wa)
08-22-2007 10:47:50
"One mechanic speculated....."
The mechanic may very well be right. If the hyd oil from the torque tube reservoir has leaked by the hitch piston into the transmission case then the hyd pump may be running dry.
Check both oil levels.
Joe
